- Jul 21, 2013
- 66,466
- Plaster
- Pentair Intellichlor IC-60
Note that acid is heavier then water. If poured into still water acid will settle to the bottom and affect the surface due to the localized very low pH.
You should stir the water with your pool pole in the area you added acid even with the pump running.
