Well, we trust you've already moved the acid outside somewhere. Try for a shady spot, away from anything metal, but still out of reach of small children. Just to drive that last point home, imagine how much a gallon of acid looks like a gallon of lemonade! If you have small children running around, and all-plastic storage box that can be locked is one way to go.
Heat and sunlight degrade chlorine. There is no way of knowing how much yours has degraded, and while it's possible to test its condition (if you had the right test MO), the surest way is to just try it in your pool the next time your FC is low. Use Pool Math to determine how much your FC should rise with X amount of your shock added. Add that amount after the sun goes does, while the pump is running. An hour later test your water to see if the FC went up the expected amount. lf it did, your shock is OK. If not, you can "reverse engineer" the math to see what "strength" remains in your shock. If the FC didn't go up at all, then your shock is salt water (throw it out). This is assuming you don't have algae present in your pool water, otherwise the test is invalid.
You might need to store your chlorine elsewhere, or don't stock up on it anymore.
PS. Yet another reason we all love our SWGs. My chlorine just got made this morning, 100% fresh. Hey, it just happened again! And I didn't have to store it anywhere, nor lug it home from the store. Oops, there went another fresh batch right into the pool, while I was typing! Oh, and my chlorine was cheaper than your shock. Just sayin'...
