Please, please, stop chasing after perfect numbers.
You are causing yourself unecessary work and your water chemistry is worse in the chase.
Any CSI between -0.6 and +0.6 is ok. Don't chase your CSI all around.
You have a SWG , and you are also putting Trichlor tablets in the water, and adding liquid chlorine???? Why? Use one method of chlorination at a time. SWG except in the winter when the SWG shuts down and then use liquid chlorine and that is it.
Just focus on two things and get them stable in your pool - pH and FC. Anywhere in the TFP ranges is OK...
Use our tool to find ideal chemical levels for any swimming pool. Check TFP recommended levels on pH, free chlorine, cyanuric acid, and more.
www.troublefreepool.com
