Hi all,
After adding solar and keeping our pool warmer this summer, I'm more seriously considering adding a SWG as the chlorine demand is getting more intense. The general opinion here at TFP seems to be in favor of SWGs, and that the risk of corrosion is low.
Many seemingly informed sites note the importance that all equipment is electrically bonded. My biggest corrosion concern would be the metal pool frame, but while I'm not going to jackhammer through the gunite to test its resistance from one end to the other, I would guess the fact that it's a metal grid means it is well-bonded to itself.
I see a bare copper wire coming up through the slab with the plumbing to the equipment, which connects to the pump (we don't have a heater) and brings me to my main questions.
Lastly, not a corrosion concern exactly, but we have an ipe deck around the pool (outside the ~15" cement coping). If anyone else has hardwood around their salt water pool, it would be great to hear any reports good or bad, or other suggested maintenance.
Thanks, everyone. We put in our pool a couple years ago and TFP has been an amazing resource.
Matt
- Should people converting to salt water test continuity from something metal around the pool (the frame around the light is the only option I see) to the metal wire coming up to the equipment?
- What pool equipment should typically have bonding connections?
- Do others who install SWGs also install sacrificial anodes?
- What are the biggest corrosion risks, assuming an outdoor pool and no soft stone?
Matt
