Mixing different chemicals in the same bucket
Nooooooooo! Please don't. Residual chemicals have been known to explode when in contact with a different version of that chemical.
In fact, please don't put calcium in any dilution bucket. Just sprinkle over the deep end of the pool and brush. Calcium actually heats up (exothermic) and you don't want to be near that.
What type of pool do you have? Do you have a salt system? Plaster pools, and salt cells are damaged by the use of dry acid. Muriatic acid is preferred, and for that you just pour in a thin stream in front of a moving water return. I always brush well around there after.
Maddie :flower:
Reactions: Mdragger88
Cal Hypo is not a recommended chemical, but can be applied the same as calcium chloride --
Calcium products should be spread across the surface of the deep end of the pool.
Be sure you brush the pool really well to be sure it is all dissolved. It can stain a liner pool very quickly.
