We have an in-ground pool of about 50,000L in Alberta Canada. This past winter the cover we used failed in several places and the water underneath was horribly dirty.
We added excess liquid chlorine like we do every spring, let it sit a week and found chlorine was basically gone.
We tried again, and followed the instructions from our local pool shop but after 3+ weeks of several super chlorinations, non-chlorine shock, pool perfect etc the water is a milky white and isn’t getting better.
the stuff they told us to add to the pool also reduced the Ph lower than we were comfortable with (while alkinity was high.) and so we decided to drain back to winter levels and fill it up with clean water.
instead of following the pool store’s instructions, and add a bunch of junk into the water again, we bought this app and I’ve been doing some reading on TFP forums.
I’m hoping you might have advice for us to get our pool water cleared up so we can start using it.
it isn’t green algae, but still milky. (Photos are from before the draining was done)
Thank you for your help!
below are my logs. Note that we bought the app part-way through this process so not everything is logged, but I’ve tried to make it as accurate as possible.
Cabin Pool
Build Type: Vinyl
Volume: 51000 liters
Latest Test Result Summary:
FC: 0.1 (12 minutes ago)
CC: 0.4 (12 minutes ago)
pH: 7.2 (12 minutes ago)
TA: 108 (12 minutes ago)
CH: 155 (12 minutes ago)
CYA: 30 (12 minutes ago)
Notes 2021-06-01 @ 11:55 AM
Phosphates = 5 ppb
Copper = 0.4 ppm
Iron = 0 ppm
Test Results 2021-06-01 @ 11:54 AM
Free Chlorine: 0.1
Combined Chlorine: 0.4
pH: 7.2
Total Alkalinity: 108
Calcium Hardness: 155
CYA: 30
Notes 2021-06-01 @ 09:00 AM
Emptied the pool to winter levels and refilled with 3,500 (full truck load) of fresh water
Test Results 2021-05-30 @ 10:37 AM
Free Chlorine: 1.0
Combined Chlorine: 1.0
pH: 6.4
Total Alkalinity: 150
Calcium Hardness: 300
Maintenance 2021-05-30 @ 09:30 AM
Maintenance 2021-05-29 @ 11:20 PM
Maintenance 2021-05-29 @ 09:30 PM
Cleaned Filter
Pressure: 12.5
Maintenance 2021-05-29 @ 09:07 PM
Vacuumed
Pressure: 14.5
Test Results 2021-05-29 @ 06:40 PM
Free Chlorine: 5.0
pH: 6.5
Notes 2021-05-29 @ 12:04 PM
Phos free to skimmer
Pool perfect to pool
Maintenance 2021-05-29 @ 12:05 PM
Cleaned Filter, Backwashed
Pressure: 11.5
Notes 2021-05-29 @ 11:51 AM
Opened air to aerate pool
Maintenance 2021-05-29 @ 11:04 AM
Pressure: 9
Notes 2021-05-28 @ 05:03 PM
Pool perfect total to pool
Notes 2021-05-28 @ 12:05 PM
Added 2.5 KG of brite plus (non-chlorinated shock)
Notes 2021-05-28 @ 11:58 AM
Copper = 0.3 ppm
Iron = 0 ppm
Phosphates = 172 ppb
Test Results 2021-05-28 @ 04:06 PM
Free Chlorine: 6.9
Combined Chlorine: 3.6
pH: 7.0
Total Alkalinity: 120
Calcium Hardness: 153
CYA: 41
Notes 2021-05-26 @ 12:05 PM
Added brite plus (non-chlorinated shock)
Notes 2021-05-26 @ 12:03 PM
Pool perfect total
Notes 2021-05-26 @ 11:57 AM
Copper = 0.3 ppm
Iron = 0 ppm
Phosphates = 257 ppm
Test Results 2021-05-26 @ 10:00 AM
Free Chlorine: 13.9
Combined Chlorine: 4.6
pH: 7.1
Total Alkalinity: 125
Calcium Hardness: 154
CYA: 43
Chemical Addition 2021-05-25 @ 07:00 PM
+ 20 Liters of Bleach
Cabin Pool
Build Type: Vinyl
Phosphates = 5 ppb
Copper = 0.4 ppm
Iron = 0 ppm
Free Chlorine: 0.1
pH: 7.2
CYA: 30
Free Chlorine: 1.0
pH: 6.4
Cleaned Filter
Pressure: 12.5
Vacuumed
Pressure: 14.5
Free Chlorine: 5.0
pH: 6.5
Pressure: 11.5
Pressure: 9
Copper = 0.3 ppm
Iron = 0 ppm
Free Chlorine: 6.9
pH: 7.0
CYA: 41
Pool perfect total
Copper = 0.3 ppm
Iron = 0 ppm
Free Chlorine: 13.9
pH: 7.1
CYA: 43
