I had a question about measuring pH using the kit and how chlorine/bromine levels affect accurate measurements. Can anyone comment on this?
Also, for the TA test, you first add 2 drops of thiosulfate presumably to neutralize chlorine/bromine so that you get an accurate reading. However, for the pH test, you do not add any chlorine/bromine neutralizer. Would it not be a good idea to add a couple drops of thiosulfate before you do your pH to get a more accurate reading?
