Mastertemp SFS error
Most common reason is low water flow through the heater. Check your pump RPM and filter pressure and clean your filter.
Check valves are in the proper position.
Check the interior for obstructed venting (intake and exhaust). Animal nests, spiders, mud dauber nests against the air blower vent, can all block the air flow and lead to an overheat and SFS error.
