We have an in ground pool with hot tub. We have a mastertemp 400. We recently had a stack flue sensor error. I replaced the sensor. At the same time we have had an issue with the hot tub heating to about 95 (automation temperature) but the screen of the mastertemp says 102 and it then shuts off.
I have now replaced the stack flue sensor, the thermistor, and the flow sensor. The issue continues. The temp on the mastertemp shows 102+. The temp on the automation panel shows 95. The heater turns off.
What should I look at next?
