MasterTemp heaters
rjb1211
217
Harrisburg,PA
Pentair Intellichlor IC-40
In looking at the manual it does not appear that you can change the location of the controls in relation to the plumbing connections. Is that correct?
There are four wingnuts under the four corners of the top that let it be removed and rotated so the control panel can face in any direction.
Thank you. Since you said it was able to be done I scoured the manual and found the section that gives the instructions on how to do it.
