- Jul 21, 2013
- 65,607
- Plaster
- Pentair Intellichlor IC-60
To get that heater running I think you need to go after the corrosion. That means unbolting everything and cleaning the corrosion off down to the bare metal. Then see how much meat you really have left on some pieces.
If you disassemble it all and clean it up either it will work or you will know you need to replace the heater. What is your time worth?
