Hi,
I have a Pentair MasterTemp 400 (installed new in April 2015). The pool heats just fine. I can get the entire 30,000-gallon pool to 90 degrees. We use the heater a lot in the spring and fall.
Recently, when I heat the spa, however, the temperature only gets to about 95 degrees and then the heater turns off. The heater display says 104 degrees. I have no errors and the service light is not on. I confirmed with a handheld thermometer that the spa temp is actually 95 degrees. This is a recent problem. A few weeks ago the spa worked as expected.
After looking online, I suspected that I had a bad Thermistor. I replaced that, but it did not fix the problem. My next step is to replace the Thermal Regulator and then the High Limit Switch (I ordered both from Amazon).
My question is, am I missing something? I really thought that replacing the Thermistor would work since it seems like for safety reasons the heater is turning off since it thinks the spa is 104 degrees.
Andy
30,000 Gallon Pool
MasterTemp 400 Heater
Jandy VS FloPro variable speed
Pentair FNS Filter
Polaris PB4-50 Booster Pump
Hayward CL220 Auto Chlorinator
Jandy iAquaLink
Zodiac color changing LED pool lights
Andy
30,000 Gallon Pool
Pentair FNS Filter
Jandy iAquaLink
