Searching around, it seems like the issue could be a lot of different things. I'm hoping you guys could point me in the right direction. The warranty expired, so this will be my first attempt at a repair.
Last week, the heater worked fine. Yesterday, it started short cycling. I think it would run for 30-40 minutes and then stop heating. The heater display looked like it normally does when it's on; there was no error code. The intellicenter app made it look like the heater was working, but there was no noise and no heat.
This morning, I went out there hoping to see an error code. I turned it on and it only ran for about 10 minutes, then stopped. The "Service Heater" light is now on if I try to turn on the heater. Still no error code on the display.
The only issue I had to this point was the Stack Flow Sensor had to be replaced about 2 years ago while under warranty. It did something similar (short runs and cut off), but I don't recall if it gave me an error code.
Any guidance on troubleshooting would be appreciated.!
