Hi. Bought our house this past July. The heater - Mastertemp 400 - worked fine. We used it at least once per month through November. At one point - I think in August - Error 01 (Thermistor) was a problem. I replaced that, but later found the real problem was the connector on the control board. Cleaned that up and it's been fine.
Tried the heater a couple of days ago. It goes through the normal display cycle 128, r=8,..., current water temp - which is 41F. Fan runs. Unit fires up. Stack puts out warm air. But after 6 seconds (every time), the heater shuts itself off. After that...
This is not a case where the heater stops and then restarts itself (which I've read can be regulator problems). Once it shuts down, it stays down for at least 15 minutes, which is the longest I've waited before turning off.
The next thing in the trouble shooting chart with these symptoms is "replace control board." Before I plunk down $300, is there anything else I should try?
A couple of other facts:
- Mild smell of gas that quickly goes away.
- The fan keeps running.
- "Heating" light is on.
- No error codes.
- No internal error LEDs. (The "Spa mode" green LED is lit.)
- I'm confident there aren't flow issues. Cleaned the filter a month ago, and pressure has barely changed. Also can see obvious churn in the spa. The jets are putting out.
- Inside of unit looks normal. No evidence of animal nesting or weather damage. No leaks.
