A pool will come out of the ground if there is enough ground water surrounding it. That's what hydrostatic drains are for, they allow water into the pool to equalize so the pool won't lift. You may have one. Many times they are located under the main drain cover with the suction port.Also, this is PAST my area of expertise, but I wouldn't worry about the pool lifting/floating if it goes empty. You're in FL... so your ground won't freeze and shift. I've had my plaster pool EMPTY last Summer for close to a week or two without issue (not by choice but....). Maybe someone else can chip in, but I believe the lifting/pooling issue is just an issue for winters and cold weather and things of that nature. That's what I've been told by two different pool builders/service companies I've worked with. An empty plaster pool in Summer isn't great, and can hurt the plaster especially in really hot sun for ongoing days but, lifting? I don't think that's a concern. Someone correct me if I'm wrong please.
If you do scuba, remove the main drain cover and check. If you don't have one, mix a ball of hydraulic cement, or a large ball of epoxy, and plug the drain port. You don't really need it anyway. A leak in main drain plumbing is an extensive repair, usually involving jack hammering into the pool wall.
National Plasterer's Council recommends a pool not be left dry in the sun for more than 5 days.
