I have a simple in ground setup. I have two valves that can be shut off. One valve shuts off main drain and the other the skimmer. Does it hurt any to shut off one valves completely if I want sediment to be sucked into main drain or if I want leaves to go faster into the skimmer? All I notice is the pressure dropping by 2 psi from 14 to 12 psi on filter gauge that is all. Am I hurting anything? Does the pressure drop because the pump realizes it's only pushing one suction line so it works less hard?
