Hello my friend is purchasing a home with a pool and the owner says when the original pool heater was removed the contractor disconnected the main drain (closed it off for non use) and the pool now filters through the skimmer return and the pool cleaner only. Is it ok to seal off the main drain like that and only use the skimmer as the main filtration system? Thanks ahead of time.
