I have a 19000 finite pool in montgomery County TX. Due to the use of Chlorine tabs my CYA is now 150. I’m afraid of drawing down down the pool so I was told to put a hose in the bottom of the shallow end and add tap water and let the pool water drain out the overflow 1.5”in drain. Will that work? I’m planning to add 13000 gal to the pool slowly as to not overflow the pool.
Help!
Help!
