Do i somehow snake the return lines?Ok, so it looks like a clog somewhere from the chlorinator to the returns.
Do i somehow snake the return lines or lower the water under the return lines and somehow blow or suction it out?Ok, so it looks like a clog somewhere from the chlorinator to the returns.
Ill remove the fittings now. How would i reverse the water flow? Sorry difficult to see the returns from ugly water.Remove the return fittings and maybe something will come out.
Thats possible something from heater made its way into the return. I disconnected the heater due to last year startup it was pouring out water from something broken inside. The heater was due to go as it was very old.Maybe a piece from inside the heater came loose and went into the return line?
Can you remove these unions and show a picture looking into the inlet and outlet?
You can run a temporary line from the filter to the pool until the line gets unclogged.
HYDROMAXX 1-1/2 in. x 50 ft. PVC Schedule 40 White Ultra Flexible Pipe 2201112050 - The Home Depot
Our white Ultra Flex Flexible PVC Pipe is commonly used for pools, spas, and other water features where the utilization of rigid pipe is either not practical or not desirable. Commonly referred to as PVC pool or spa hose, flexible PVC tubing and flexible PVC, our white Ultra Flex flexible PVC...www.homedepot.com
Yes nothing is stuck against the eyeballs. ive removed them and there are no obstructions at the front.DMS,
If nothing is obviously stuck against the eyeballs, you can use a drain king and a garden house to force water backwards up to your tab feeder connector.
Jim R.
Heyward H series. H200Looks like part of the bypass is missing.
What is the heater model number?
When i hold my hand over the return thats working the other return does flow out strong though.Maybe this black piece came loose and went into the line.
But, is the pump at full flow?When I hold my hand over the return that's working the other return does flow out strong though.
Yes, but ive tried it at any rpm and it flows out when the other working return is covered. There was air bubbles last time coming out the non working return although there were times where there were not any air bubbles.But, is the pump at full flow?
Unscrew this plug and you will be able to pull back the part to see if the black disc is on the end.
