Low Water Pressure - Nothing has changed
embeleco
67
Florida, USA
Team.
I've been having my Filter Pump running on 1600RPM without issues for months. Since my pool was built last summer. Suddenly in the last two weeks I see that the pressure on the return lines is way low. I checked everything that I can possible check.. no leaks that I know.. Skimmer basket is clean. PSI on the filter looks good reading 5-10. If I increase the RPM return works normally but on my current 1600 value it is not the same as it was before. My SWG is still running without issues as well. I cleaned my filter like 2 months ago.. not sure if that is the issue.. I will try cleaning it up this weekend.
Just wanted to see your opinion on the matter. My pool knowledge is almost zip!
-JJ
Do you know what your filter pressure was when the filter was clean?
If not, time to clean the filter. That is normally the cause of diminished flow.
Reactions: markayash
