I could use some guidance here.
Before I start, this pool is about a year old. Things have been otherwise stable except for it's constant demand to add acid because of rising PH.
Recently (stupid me) left the hose on over night and I estimate that I replaced nearly 15,000g of water by the time I noticed.
I was able to get things to quickly bounce back since it was mostly the CYA and FC that was diluted with a slightly higher PH (8.4).
Here's my latest test:
FC: 3
CC: 0.5
TC: 3.5
CYA: 60
PH: 7.2
TA: 40
So, I was previously using the ATC PH tester, I continued to add Muriatic acid, only to realize last night that according to multiple drop tests, the PH was a full point off.
I now realize it needs to be re-calibrated but an 8.4 reading was really closer to 7.2-7.4 and after trying to reduce it...the PH was likely closer to 6.2-6.4 at times after addition of acid.
My biggest issue:
Kids hair is turning green, eyes are red, and all complain of itch skin the next day.
Is it possible that the low TA is creating a corrosive environment and causing either the Gas Heater or Heat Pump to introduce copper?
I've never used any copper based algicides or otherwise in the pool. I'm assuming a copper issue because of the green hair, but these kids swim in 3 different pools each week and I can't pin-point if it's mine.
I've searched enough on here to assume a TA of 40 is not good and I should really target 60. Does this sound correct?
I'm estimating an addition of 5lbs of baking soda.
I will not add anything until I get everyone's valued insight here on what I should be doing.
FC: 3
CC: 0.5
TC: 3.5
CYA: 60
PH: 7.2
TA: 40
My biggest issue:
