Here are my full set of results. Water at the moment is clear. Been keeping my FC at or around 8 all summer but occasionally even at 8 my water sometimes gets a tad cloudy and a little green and then I add about 8 ozs of Cal Hypo 68% (65% chlorine listed). I have a vinyl above ground pool (no heater). I should also add whenever the pool isn't in use we always have the solar cover on to reduce FC usage been burned up by the sun. My intex SWG isn't very good and we only run it about 3 hours a day since I have a 1 speed pump, so I supplement with about 2 cups of bleach 2 times a week.
using TF-100:
FC - 7.5
CYA - 60
PH - in between 7.2 and 7.5 color. Going to add about 7 ozs of borax to bring up a little
Salt - 3000
Calcium Hardness - 50
Total Alk - 40
using TF-100:
FC - 7.5
CYA - 60
Salt - 3000
Total Alk - 40
