My in ground pool has 3 skimmers (shallow end, middle, deep end) with the deep end skimmer closest to the pump. It doesn't have a main drain, so those are the only lines returning back to pump. There is a ball valve for each of the skimmer lines returning into the pump. Currently only the shallow end skimmer is actually skimming the pool - meaning leaves and debris actually go into the skimmer. For the other two skimmers the leaves and debris just stay in the pool and don't go into those skimmers. For these two skimmers I can feel some suction by the hole at the bottom of the skimmer but again the leaves and debris in front of the skimmer don't get pulled in. I tried different things with the skimmer ball valves to see if that could help determine what's going on:
All valves open:
- shallow skimmer high suction and pulls debris in
- middle skimmer very low suction and not pulling debris in
- deep skimmer very low suction and not pulling debris in
- filter pressure solid at 19psi
Only Shallow skimmer valve open:
- high suction and pulls debris in
Only Middle skimmer valve open:
- low suction not puling debris in
- filter pressure below 10 psi and pump makes a whiny sound off and on
Only Deep skimmer valve open:
- some suction and pulls some debris in
- filter pressure solid at 19 psi
Anyone have any ideas/suggestions on what's going on and how to fix it?
All valves open:
