Hi, thank you.Check the suction side for a blockage. Are you getting air out of the returns?
Has the pressure gauge shown filter pressure prior to this?
Thank you. I did a few of those things before. I did the complete list this time. Couldn't tell if it made any difference. I then poked a couple fingers as far as they would go into the hole where the pump basket sits and could feel some debris. I couldn't get it out, though. I took a small screwdriver and poked around in there and was finally able to extract some debris (plant/tree stuff). I can't tell whether there is more.Suction side is from the pool to the pump. Check your skimmer to be sure it is not plugged with leaves or the weir door in the skimmer is stuck. Check your water level, it needs to be half way up the skimmer opening.
If those are all fine, check the pump basket to see if it is full of debris.
