Hi, new to forum. I'm in Arizona and it's almost too hot to work on the pool, but I must! I've had three different pool repair guys out here the last year and a half, and I still have the same problem. I have a new variable pool pump which I'm finally figuring out how to use, and I've replaced just about everything except the pool itself, but I still have low pressure on the Hayward vacuum, so it's not picking up the dead algae and the pool stays green. I've replace the old vacuum, but new one does the same, they run for a short while and then just stop. Maybe they are bogged down by the algae. I had the pool emptied last April, and just didn't want to do it again, and now it's too late because the heat has returned here and I really can't afford for the pool to crack... Anyway, now I'm wondering if there is a plastic bag or something clogging a line somewhere. They blow over the back wall into the pool on occasion. I had one of the guys blow out the lines, but he took a fraction of the time that the YouTube video guy took, so who knows if that was even helpful, or just a scam job. I backwash, but don't want to pay $85 for the latest guy to pull the DE filters out and clean. I can't pull them out right now myself, still recovering from a couple surgeries... I do take the lid off and wash as much as I can without taking them out, but the algae is so thick and the pressure so low, that nothing improves. So, does anyone have an idea about the pressure, and what I can do about fixing it? Or even recommend a pool guy that actually can troubleshoot, instead of just replacing this and that? Thank you for any input...
JJ
JJ
