Hello!
I've recently started trying to maintain our pool chemicals, and I need some help.
Yesterday, our pool was not reading any chlorine. I went to the pool store and was advised to add shock to the pool which I did. We currently use the Sutro testing cartridge, and this morning it was reading the TA between 181-200. The PH was at 7.8, but I was advised to use MA to try to lower the TA. I added the muriatic acid, which then decreased the PH to 7. What do you recommend I do next? Should I add borax or soda ash to increase the ph? If so, is there one more effective than the other?
Here are the current readings:
PH = 7.0
FC= 1.6
TA= 181-200
All help is greatly appreciated! Thank you
PH = 7.0
FC= 1.6
TA= 181-200
