If you drain a vinyl liner and leave it drained the liner will shrink. You can drain an above ground pool without worrying about the liner floating. As I understand, the plan proposed is to drain the pool down to about 18" deep and immediately refill with fresh water. As long as you are not draining and leaving the pool empty for days at a time your liner should be fine.
