Low out flow cartridge filter
zea3
11,759
Houston, Texas
If you drain a vinyl liner and leave it drained the liner will shrink. You can drain an above ground pool without worrying about the liner floating. As I understand, the plan proposed is to drain the pool down to about 18" deep and immediately refill with fresh water. As long as you are not draining and leaving the pool empty for days at a time your liner should be fine.
Poolzzz
373
Vancouver, BC
Pool was a swampy green (wasn't put up in 2018).
7 yrs old and wasn't put up in 2018...sounds like an Intex style pool?
If so you can drain down to a few inches easily. Also liner damage won't be an issue since they are designed to be drained for months at a time. If going to the trouble of draining an Intex style pool I wouldn't stop at 18" but go for 6 inches or so.
breanna96
24
Louisiana
Drained the pool to 18 inches. Got in and got all the leaves out. Had way more then I thought there was. Also had the water pump pumping out water while it was filling up just to get more clean water in! Now the pool is filing up. When it's filled should I balance the water first or get rid of the ammonia first? And to get rid of the ammonia is it just check and add liquid chlorine to 10ppm every 15 minutes?
breanna96
24
Louisiana
I've dont the ammonia thing twice first time fc was at 4.8 second time was at 8.4. Is it possible it was really that easy to get rid of the ammonia? Gonna test fc again in 10 minutes to see where it's at
Poolzzz
373
Vancouver, BC
Are you using a 25ml water sample where each drop is 0.2ppm? That's more precision than needed. Use 10ml water sample where each drop is 0.5ppm. Saves reagent and still plenty good enough.
breanna96
24
Louisiana
Yes I was using 25ml but from now on I'll use 10ml!
Ph 8.0 so I added ph down and will retest in 2 hours to see of it needs more.
Ta 130
Ch 70
And the one thing I forgot to get is cya :hammer:
Have about half a pound left from last time so will add that and get more
Will continue to SLAM!!
How often should I be testing fc while slamming?
And the out flow still slows down after about 30 minutes. Should I just take the filter out or clean it every 30 minutes? It doesn't even look dirty when I clean it.
mknauss
22,725
Laughlin, NV
Test your FC and add chlorine as often as possible. Once FC is holding better you can get to 3 or 4 times per day.
The cartridge is filtering out stuff. What comes off of it when you spray it clean?
breanna96
24
Louisiana
Yes it's a single cartridge. I used the filter I had it was 2 years old. Thought the filter was the problem so i went and bought a new one and its doing the same thing. New filter worked good for about 4 hours then stated to slow down again.
mknauss
22,725
Laughlin, NV
If a new one does the same it is solids. May be very light colored dead algae. So may not see it when you clean them. Alternate the filter cartridges so you can keep the pool filtering while you clean the dirty one.
