Low CH, high alkalinity and PH with chlorine SWG
Embers
16
Antioch, CA
Hello. Am a bit frustrated with my pool water balance. My current chemical #s are
Salt level 3400
3.5 ppm FC
.5 ppm TC
32 ppm CYA
TA 150 ppm
PH between 7.8 and 8.0
CH 100 ppm
I have added the amounts of Muriatic acid indicated by the drops test 3 times now and PH and TA still remain high. Pool is 28k gallons so had to do some math to determine how much to add as the booklet jumps from 20k gallons to 50k gallons but it wasn't difficult to figure out how much to add. Ever since I started adding the acid my hair dries crackly stiff and clumped together after swimming which it never did before. Am already into the 2nd gallon of Muriatic acid but seeing little improvement in TA and PH.
My pool is fiberglass layered over an old vinyl liner and I know my CH is supposed to be much higher in a fiberglass pool. Does the low CH have anything to do with the TA and PH being so stubborn to bring down??
mknauss
23,045
Laughlin, NV
How are you testing your water chemistry?
TA will come down as you lower pH from 8 to 7.4. Once your TA settles in the 70-80 range, only lower your pH to 7.6
What is your fill water TA and CH?
CH level does not effect pH and TA. If you wish to raise your CH, add some calcium chloride.
I am concerned with the hair issue. Be sure you are getting accurate test results.
Embers
16
Antioch, CA
My fill water is:
TA 75
PH is over 8 but oddly only takes one drop of R-0005 acid demand reagent to drop it to 7.4
CH 50
mknauss
23,045
Laughlin, NV
Thank you. So do add some calcium chloride. Target 200 ppm as your fill water will add some over time.
What is your Location? Can you add that to your profile?
Embers
16
Antioch, CA
Am in Antioch, CA. It used to be in my profile but I will put it back since it clearly isn't any more :)
