Lots of rain today I am guessing I should drain some water? The only option is to put a pump in pool since I don’t have the hose that connects to drain pipe..
No urgency yet to drain although your skimmer will not skim debris. You can drop a pump in and lower the water a bit or wait and see if evaporation lowers the water more then rains will add water.
If the water gets up to the top of the skimmer plastic edge I would start pumping.
