I had n't really gotten a good idea of what the salt level is yet because I don't know how to test it without the new salt meter I got and the directions for the salt meter re how to calibrate it are very confusing. But I'm sure we need some. Ask for the pool heater we've never even turned it on so I don't think that plays into the scenario. Pull temp has been around 76 - 78 the weather has been weird, it'll get warm and it gets pretty cold again like you know 65 or so sometimes 60 and we've had a lot of rain but generally during the heat of the summer it stays around 80 so it's not that far off. I will work on the instructions you gave me and will follow up with you. Thanks for everything as usual. You do know that I will learn this eventually. My brain just doesn't always work with me very well.Until today, it looks like your last CH test from 7 months ago was 100. You reported CH of 80 today.
Your signature shows you have a gas heater. You need to increase your CH to at least 200.
TA of '45' gets rounded up to 50.
Your FC is way too low.
I'd suggest an Overnight Chlorine Loss Test - if you pass, increase your CYA in anticipation of increased temperatures and dose FC according to the FC/CYA Levels chart for a non-SWG pool.
What is your salt level?
What is your water temperature?
