I recently switched from Trichlor pucks to liquid chlorine (10%) and I feel like I'm using a ton of chlorine. It might be a normal amount but I wanted to check here. My CYA is around 50, so my minimum chlorine is 4ppm with a Target of 6-8ppm, so that's what I'm striving for. But it's dropping by at least 2ppm per day and I have no CC, the water is crystal clear and no signs of algae. Should I be adding my chlorine in the dark and running my pump at night so the sun isn't zapping all my chlorine?? I feel like my CYA should be high enough to protect my chlorine. Am I missing something? Below are my other test results.
pH: 7.5
TA: 60
CH: 210
pH: 7.5
TA: 60
CH: 210
