When it comes to filtration bigger is better. Packages that include pump and filter are nice as it takes the guess work out of figuring out the flow rates.
Looks like your pool is roughly 7,092 gallons so the filter your showing is capable to handling your needs as well as being a simple plugin in play having hose adapters.
I would also consider also looking at 2 speed or variable speed pump packages. While more expensive and not necessarily plug and play up front your electric bill might be a bit happier
