Hi TFP members,
I am looking for some recommendation for my pool water balance. I am using the Taylor K-2006 and these are my most recent values.
My pool profile is:
- 20k gallon with spa
- inground gunite
- chlorine (trichlor tabs 3")
- DE Filter 60 sq ft - Pentair FNS Plus - Pressure after backwash 21 PSI
- Jacuzzi jhn 266 water heater
- Water feature with independent pump
- Pool pump pentair whisperflo 2HP
I bought the house last December and even though the plaster was not in perfect condition I have noticed a lot of new etching and calcium nodules since then. It is my first pool and I decided to take care of it myself with help from the very well known pool store. Bad idea. It wasn't until 2 months ago that I bought the Taylor kit just to find out that my TA was at 50 and CH was at 120 while the pool store has been telling me TA 110 and CH 250. So, now after spending some more time trying to balance my pool water I think I reached some sweet spot. My only concern right now is that the TA seems to be low still but I don't want to raise it and raise the PH with it.
Any recommendations from the numbers above? Should I try to increase my TA with Baking Soda and fight the PH vs TA battle?
Additional notes about my pool: When it rains heavily I have some dirt getting into the pool since my grass is about a foot from the edge of the pool and when it happens I get a green pool. Happened at least 6 times since december. My go to medicine has been 2 pounds of shock, run the pump continously, backwash 4 times, add + pounds of DE after every backwash, sometimes vacuum, and when it is clear again, test PH TA CYA FC.
Thanks
My pool profile is:
- inground gunite
Thanks
