Looking for in-ground spa repair in Los Angeles! Help!
AmyPlusOne
6
Los Angeles
Hi!
I'm looking for a pool/spa contractor to fix an unfinished in-ground spa! I'm helping the homeowner on this project so I suggested this site as place we could hopefully find someone to complete the work. Would LOVE any referrals to contractors that do great work with high attention to detail. Been following on here for years and I'm hoping the community will be able to help.
The homeowner's budget is a concern, so we are looking to keep the work focused on what is required to get the spa running reliably before a leak detection is performed.
Here's the requested scope of work (SOW) for this project that was previously determined for the contractor to complete.
We are completely open to revisions to the scope of work if the contractor advises that it's required.
1. Check / replace / seal off and relocate main drain if leaking.
2. The main return line is currently in-ground between 4”-6” deep, although it must be moved to the same depth or below the old abandoned return line.
3. Determine if the 4 suction fittings at the bottom of the spa must be replaced, and if so, replace them (an excessive amount of old cement/sealant was found inside the suction fittings, not sure why.)
4. During the course of replacing the suction fittings, the tile around those fittings will need to be replaced. There is some vintage tile available at the site that can be used if enough is available, while accounting for spares for the future. If additional tiles are needed, provide replacement sample tiles to match or complement the existing tilework. If the tile selection is not a match, we would like to review the tile design to ensure it looks intentional. Please expect to have to provide tiles for use in this project and provide a selection of tiles to be used for the homeowner's review.
5. Trench from the spa to the equipment must be dug deeper to accommodate the desired depth of return and additional lines. (They are currently very shallow). If other lines exist where the new lines are to be placed, the new lines must be routed below the existing ones to prevent the lines from being too shallow in the ground.
6. If a new suction main line is required: The same trench from the spa to the equipment could be used for both suction and return lines, the trench may need to be dug deeper to accommodate both pipes.
7. All disconnected pipes (return line or others if required) will need to be connected to the spa equipment.
8. When connecting pipes to the equipment housed in the spa shed, if possible, the homeowner would prefer if you dig under the slab and circle cut for pipe entry, and seal/cement around pipes to prevent moisture egress/ingress, instead of saw-cutting the cement foundation.
9. We have been informed that this is a split main drain spa (center floor drain/skimmer). Please verify that this is accurate and it is working as it was originally designed.
10. The main drain in the spa needs to be cleared of all dirt and debris to preserve the original skimmer/drain functionality.
11. After filling the spa with water nearing the completion of the job, please ensure the spa is not leaking. Verifications over multiple days must be scheduled to ensure the water is not leaking out of the spa/spa system from anywhere.
Thank you all so much for the help. Greatly appreciate your referrals!!
Amy
My suggestion is to find all of the pool/spa builders in your area. If they have a office building I would go visit it and chat in person with pictures of what you have already as well as that list.
Another idea is to find trusted trade people. I would start with plumbers as there seems to be quite a bit of piping needing to be done. They might have idea for other trade people you can contact.
It is going to take quite a bit of networking but you all will be better off in the end as everyone will have a full list of trustworthy trades to pick from.
Good luck!
Reactions: JoeSelf
Good luck!
Thank you so much. We did a search for all the local spa repair companies in the area and have reached out to a bunch of them. We have sent pictures and videos and we have them available for anyone else who may be referred to us.
Really hoping that one spa company can handle the entire thing rather than dealing with a number of vendors. Thanks again!
Reactions: kimkats
