Looking for agp with narrow top rail
Purple
46
Utah
Can anyone recommend a good above ground pool with narrow top rails/seats or no top seat thing at all? I’d like something without the big wide top rail.
Purple
46
Utah
Hard wall. I’ve had an Intex for the past two years and it’s great, but im ready to upgrade to something more permanent.
splashpad
2,708
SE Kansas!
I found this in an article info search
https://www.precisionpool.net/2010/03/above-ground-pool-buyers-guide/ said:
Above Ground Pool Structure
Whether you are looking at aluminum, steel, or resin one thing to compare is the width and girth of the pool’s top rails and uprights. The top rail can range from 6” to 8” and the uprights from 5″ to 7″. The wider the supports on the pool the stronger the pool will be no matter the material, so that is an important part of your pool research.
Purple
46
Utah
How has your search gone @Purple ?
Good, thanks! I found one brand that doesn’t have big top rails, Crestwood pools, which are pretty but expensive and the installation instructions looked very difficult. So I’m going to go with the saltwater lx from pool factory; the rails are wide but the brown will be less jarring than white with the general look of my yard, and the walls look nice.
Reactions: splashpad
splashpad
2,708
SE Kansas!
Awesome!
Wow those do look nice! I see what you mean about the color
Saltwater LX Swimming Pool Gallery - The Pool Factory
