Looking for 3/8” male to 3/8” female PVC coupling fitting
waterk9
3
Green Valley, AZ
Looking for a 3/8” male to 3/8” female PVC coupling fitting. The threads on my inlet pipe (float valve) have started to strip and I see that HDPoolguy had found a coupling that worked for him.
I have tried HD, Lowes and several PVC stores online. No Luck.
Any suggestions. I am down in southern Arizona.
Thanks.
ajw22
12,833
Northern NJ
Welcome to TFP.
This what you are looking for?
If not, scroll through here...
proavia
1,674
Chandler AZ
If you want a PVC 3/8" threaded female by 3/8" threaded male riser,
Google this: 3/8 PVC IPT ADAPTER MPTXFPT SCH40
You may wish to check with a local sprinkler supply to see if they stock that part.
Where is 85622? It would be best to put your city, state instead of zipcode.
waterk9
3
Green Valley, AZ
Thanks for the reply.
I am in Green Valley, Arizona...just south of Tucson.
waterk9
3
Green Valley, AZ
Welcome to TFP.
But no, I need a PVC fitting with threads on both ends male/female.
proavia
1,674
Chandler AZ
I believe the Google search showed one hit in Tucson. Also try Sprinklerworld, Ewing or Horizon - all 3 have sprinkler parts and might have that fitting. May be easier to call around then drive up to the "big city".
JamesW
17,330
What you're looking for doesn't make much sense.
You won't be doing anything other than making a minor extension.
Do you have a picture of the problem?
Fuldo
203
Port Orange, FL
The OP mentioned having a stripped thread. I'm guessing he's thinking of mounting a nipple onto/into the stripped area but use pipe cement to lock and seal it. That would provide a good thread again on the other end.
cfherrman
2,435
Hays, Kansas
Get a threaded toe nipple, cut it in half, glue it into a collar that is one side slip and other side threaded.
Or
Get a close 3/8 PVC nipple, the a threaded PVC collar
I would be surprised if they make a one piece nipple as your asking for as there would be no demand for it.
proavia
1,674
Chandler AZ
I think the OP wants to keep the fitting as short/compact as possible. I believe the intended use is on an auto-fill - and if like my in-deck auto-fill, uses a ballcock to supply and also adjust the water height. Mine has restricted distance between the top of the ballcock (similar to a Fluidmaster valve) and the lid (which is flush with the deck). Using a short nipple and a coupling instead of the above fitting would probably result in the overall assembly (nipple, coupler, ballcock) being too tall for the lid to fit correctly.
The link in this post is just one of several places that supply this fitting. If the OP does the Google search as suggested in post #3, there will be a list of possible suppliers.
