- Jun 7, 2017
- 9,113
- Plaster
- Jandy Aquapure 1400
My pool for practical purposes is done. My PB has turned over startup and initial maintenance to a pool maintenance company. He has been out twice so far and both times he stuck a test strip in the water and based all of his additions on that. Mostly dumping muriatic at first which I get - it is a new pool and also I get you don't need to really test a new pool right away as you know what it in the water. 2nd time he came out almost 2 weeks later, same story. Barely looks at the strip and throws a couple pucks in the skimmer and launches a few things into the pool. I mentioned to him TFP and he chuckled and said not to listen to any advice that I get on here since you guys are only familiar with your pool and not my pool. He sees hundreds of pools so his opinion is infinitely better. I explained that the TFP advice was advice for all pools but it fell on deaf ears. Also he has yet to set up my very expensive automation system and suggested I just keep my variable speed pump on high all the time. Basically I guess he thinks my automation is so I can turn my waterfalls on and off from the remote. Also seems to be some options on the remote screen that do nothing which he doesn't know how to get rid of. In the 2 visits he has made he has yet to install my diving board even though I remind him each time. He claims to have forgotten it but his car is a total disaster and I think he just cannot fit it with the mess. I honestly think he doesn't know how to program the Aqualink.
I did a full battery of testing this weekend and results are not as bad as I thought. I did upgrade to premium so I can track my pool testing.
FC 0.5 (Added 1 gallon of bleach from the pool calculator and 2 hours later it was close to 5)
CC 0.5
pH 7.3
TA 50
CH 250
CYA 0
Temp 83
So I am going to contact him today and tell him to drop off ALL of my salt that I paid for when he comes to install the diving board. He will put in another puck no doubt which I will toss when he leaves. I'll then call the PB and tell them that I do not need anyone else from that company to ever come back.
I ordered CYA and baking soda from Amazon and picked up some regular bleach (8.25%) from Safeway. I'll go to Walmart this week for a better deal.
TFP way ALL THE WAY!
CC 0.5
pH 7.3
TA 50
CH 250
CYA 0
Temp 83
