I re-plumbed my pool pump area about 3 years ago, and all has been fine - but about a month ago, I started having some air leakage into the skimmer basket throughout the course of the day. I run my variable speed pump at around 1900RPM for 18hrs a day, and then 2400 and 2900 for the rest of the night - running the pump at full speed will successfully purge the pot of air, but it starts to leak back in over time at the lower speeds; there is a decent sized bubble (50% of the lid) by the end of those 18 hours.
I don't have a super complicated suction side setup, and I have already checked the pot lid and drain plug o-rings and applied a fairly heavy amount of lube to help them seat properly. I have also checked the o-ring on the union on the input side of the pump - it is seated in the groove properly and doesn't appear to be an issue. Assuming it isn't the Jandy valve (the screws are all tight), how do I go about finding which PVC joint is leaking air? I am assuming this wouldn't be caused by the sand filter, the heater, or the pump housing itself, but please help me understand if that is an incorrect assumption.
I should also add that I get the problem regardless of whether the skimmer or the main drain are selected.
Any help is welcome.
Thanks
Thanks
