E,
The wires go to very specific locations.. For now, I would not worry about your relays, as I suspect the ones that are not connected are not used.
The relay wires only have two pins.. The valve wires have three pins and those are the ones you need to make the valves turn. You should have four valve wires.. One for the Intake valve, one for the Return valve, and one for your Slide valve... and one for your Cleaner... Whoever took them off should have marked them somehow.. If not, you will have to do a little troubleshooting..
Assuming they are not marked..
Plug one of the valve into the Intake connection. Switch between the pool and spa and see which valve moves.. You will then know which valve is on the other end of that wire.. Do that one at a time for each of the three valves.. Once you know were each wire goes, you can plug them in.. I would mark them as you do them..
In case you did not know, the Intake valve is in front of the pump.. The Return valve is where the water goes back to the pool or spa. Your Slide valve should be plugged in port A.. And your Cleaner is valve B..
Please let me know if that is not clear..
Jim R.
Jim R.
