My 18 x 36 unground pool was installed last September. As the weather is relatively mild in North Alabama, I decided to leave it open and the pump running, with the SWG off, during the winter months. I placed a "sock" in the skimmer basket to help limit the debris getting back to the pump. Both the skimmer and baskets have been checked and cleaned at least weekly.
Last week my wife was looking into the pump basket window to see if it needed cleaning. She told me there was something in the basket that she was not going to remove. I had to laugh at my squeamish wife, as I strolled over to assess her issue. To my surprise, there was a mole in the pump basket (see attached picture). I also noted there was an air pocket about the size of a golf ball inside the pump basket, plus small b-b size bubbles entering the basket. I had never noted air in the basket area previously.
Removed the mole from the pump basket and verified the basket seal was good. I turned the pump on and it went into prime mode. During the prime cycle there was a virtual tornado of bubbles passing through the basket. Once the prime cycle ceased, and the pump returned to a slower speed, the golf ball air pocket returned with the small bubbles coming back in and exiting toward the impeller.
Now for the question of the moment. Is it obvious I have a leak? There is absolutely no way the mole entered the suction line from the skimmer. Is it possible it was drawn into the line at a leak or even chewed into the line causing a leak? If a hole in the suction line is large enough to pass the mole, would that not cause much larger air bubbles? The mole is not as big as it appears in the picture. I placed a carpenter bee next to it so it is possible to get an idea of the moles true size. As an added note, the pool is not loosing water.
I spoke with the pool installer, who really is as perplexed as I am. With our state under the "shelter at home" mandate due to the CV-19 issue, I am not even sure I can get him out here to look this over.
Any input and thoughts would be appreciated.
Good Bless,
BigT
Good Bless,
BigT
