Keithw,
One thing, you can not tap into the pump drain plug. I wrote on another thread that when you do this you will have water coming into the LQ not going out. The pump drain plug will push pressure out, not suck it in, mine did anyways . I think it is because the drain plug is on the far outside of the impeller enclosure which is the area of the pump that pushes, the water into the filter.
I put my tap into my strainer basket drain plug, that worked really good.
Brian
Brian
