Hello all-I have a couple questions and need your expert advice please.
First…I had our Buckeye concrete pool (fiberglass sides) repainted 3 weeks ago. The alkalinity after filling was 350. I used liquid Sanygen pH down to reduce the alkalinity and then aerated to bring pH back up. The alkalinity is now at 160. The gentleman who did the painting said I needed to keep the alkalinity between 140-180 to prevent chalking of the epoxy paint. (I failed to ask if he meant for a particular time period or always…) I know that is quite a bit higher than recommended here. Any thoughts?
Second…the Sanygen pH down sold by the pool store is liquid sulfuric acid (photos below). I have seen the info here about preferences for muriatic acid vs dry acid and understand that sulfates can harm the SWG and concrete. I am no chemist…Does the same hold true for liquid sulfuric acid?Thanks in advance!
Current readiings (pool is sparkling!):
FC 5.5
pH 7.6
TA 160
CH 260
CYA 60
Salt 3400
FC 5.5
pH 7.6
TA 160
CH 260
CYA 60
Salt 3400
