- May 31, 2021
- 8
- Fiberglass
- Pentair Intellichlor IC-40
Homemade 30k ingrown pool. SWG and glass media in sand filter with new hayward heater. Rubber lined pool and all plastic lines throughout. Trace metal (iron and Cooper .1 on ea) I'm sequestrating with GLB Sequa-Sol. I'm absolutely done with pool stores. I'm in Rural PA and NOONE....I MEAN NOBODY knows much about pools here. They all sell what the computer spits out and what will maximize your purchase to fix the next nightmare that the chemicals will surely cause. I've never been able to get my chlorine levels up. Lots of history for sure but right now I'm trying to recover from a phosphate removal that has left me cloudy for 7 days. I'm filtering 24/7 and adding chlorine from Bleach to try and keep some kind of reading....I used 8 gallons of bleach 2 days ago to shock pool...with SWG running at 100%. Never had a FC reading...Stabilizer was added a few days before per pool store and is now 100ppm. Thier window is 30ppm to 150ppm. But now I can't get chlorine to stay with me at all. So I have cloudy blue water that I can't seem to clear and no chlorine. It's clearing very little and has been this cloudy since the phosphate treatment that I didn't need to do.... so....
1. Do I put more sequestrant in and shock every night until it clears.
2. Does "In the swim " pool shock that is calcium hypochlorite degrade my sequestrant??
3. Should I use a floculant to clear the cloudy???
Current numbers:
Chlorine 0
FC. 0
Ph. 7.6
Hardness 100
Alkalinity 127
CYA 100
30000 gallons
Salt 3200
Current numbers:
Chlorine 0
FC. 0
Ph. 7.6
Hardness 100
Alkalinity 127
CYA 100
30000 gallons
Salt 3200
