TFP Method - Alterations to reduce time, but spend a little more $$
Hi,
I have been reading this forum using it for advise for about two years. I plan to start contributing now with some of my own experiences and this will be my first post.
I have been following the TFP method with some exceptions and will explain why below. I would like to get feedback on whether I am wrong, or whether there can be TFP method that requires less time, but allows for a little more chemical budget (still a lot cheaper than a PG).
I switched over to a SWG last year and had issues all summer with PH rise, which I believe was due to a higher TA than recommended for SWG.
TL
R, I use Leslies Fresh n Clear, Dry Acid, Liquid Stabilizer, and Natural Chemistry Pool Perfect + Phos free in addition to TFP Recommendations. I spend a little more on chemicals to reduce my need to test often and go through a SLAM to remove CC.
1. I used Dry Acid to lower it as I am still not comfortable handling Muriatic Acid and had some already from prior to the upgrade. I know this is not good for the SWG, but is it bad enough that I should figure out how to safely use and store Muriatic acid?
2. I use Leslie's Fresh n Clear weekly on Sunday evenings to get rid of CC after the normal weekend load of kids and sun block. The TFP alternative to this is to SLAM the pool every week (time consuming). Typically my CC is 0 on Saturday morning and .5 - 1 Sunday evening. I run my pump extra time on Saturdays and Sundays, but don't turn up the SWG. I also think this helps keep the PH down based on another discussion I found in the past (can't find link now)
3. I use Natural Chemistry Pool Perfect + Phos free ever since I had an algea problem a couple years ago. Since using this I have had no issues both during the year, and also during spring opening (always have phosphates < 100 before closing). TFP doesn't believe this is necessary, but Pentair does reccomend Phosphate control with their SWG
4. I always turn of my SWG prior to adding any chemicals to the skimmer (in Pentair Manual, but not detailed in instructions on TFP). Dry Acid in skimmer sock, Liquid Stabilizer (I prefer this for quicker results), phosfree.
5. I do a full test every Saturday morning and Chlorine & PH Sunday evening, I have the SWG level and pump run time figured out pretty well and adjust up when temp is above 90 degrees (I wish the Pentair Easytouch could adjust pump run time or SWG based on pool and/or outdoor temp....IFTTT).
6. The most expensive part of my pool is my new Vinyl Liner and Fiberglass steps. Should I not trust the recommendations
here over TFP?
My current test results are (from weekend):
Saturday Morning:
CL - 2-3
PH - 7.5-7.6
FC - 4
CC - 0
CH - 275 (fiberglass steps)
TA - 80
CYA - 60 (added 10oz of stabilizer, but don't plan to go above 70)
Sunday Evening:
CL - 4
PH - 7.6
FC - 5.5
CC - .5
Added my weekly Fresh n Clear & pool perfect + phosfree
