My pool will be unattended for almost 2 weeks. I took my last test today (pool temp 70) with the following results:
FC 4.5 CC 0
pH 8.2
TA 120
CH 750 (! I know!)
CYA 50
For a CSI of 1.01
After a couple of 1/4 drain & fills I got my CYA down to a reasonable number. My CH is still astronomically high due to my fill water having a CH of 625. I had planned to have a plumber connect my pool fill water to my house softened water but I find only my HOT water is softened. I'll work on all that later. I adjust chlorine levels with liquid chlorine only, but I'm sure a puck or two while I'm gone won't add much to my CYA level. My questions is, should I leave with my pH higher or lower than optimal. (my pH from the tap is 7.8). I expect some evaporation in this desert sun even though the temps should be in the 60's/70's. Will anything you see here adversely affect my pH? Do you recommend I take any other measures? I'm new to this pool game. Thanks in advance.
FC 4.5 CC 0
pH 8.2
TA 120
CH 750 (! I know!)
CYA 50
For a CSI of 1.01
