leaking water below pool pump.
It should be fine from a safety standpoint. But it will destroy bearings, etc pretty quickly. Most likely needs a new seal.
Cost for you to do the repair is $20 or so. For someone else, probably $200 or so, if they will repair it. They most likely will say you need a new pump.
