Leaking pump
doc8404
0
474
Rome, NY
Before I start tearing into this thing.
Leaking theough weep hole on the end. And also in the middle.
Repair or replace?
Agree with above. I would try to repair. Not terribly difficult but the longer it continues to leak the higher the chance that it will rust out your motor. If the motor starts getting louder it may indicate that the bearings are already going bad...
Very hard to see but if you look inside near the motor and windings, it looks like it’s corroded in there also. Not happy since this is only three years old.
New dual speed is great.
So very quiet on both high and low.
Whether it’s just appearance or better filtering, on low it appears much cleaner.
No more small pile of stuff in the middle of the pool.
Eye is aimed the same.
