Welcome to TFP! Unless you see something obvious that would indicate where the leak might be, you're almost forced to have a good leak detection inspect. They have the ability to pressurize your lines and listen with precision equipment like deck plates to isolate a leak within a few inches. If you have a filter with a multiport valve, check the WASTE line as well to ensure it's not leaking out there.
