Hello,
Last week I had to refill my pool twice in three days. Even though we had some 90 degrees temperature, I though that was odd. I had to repair a leak from the skimmer two years ago, so I thought I needed to fix the same area again. I turn off the pump, and waited a few days to see the evolution. After 4 days , the water went down around 3 inches and is down below the Skimmer. So it seems to leak from somewhere else.
I have a few question, may be somebody can help with some advice.
- by turning off the pump, does it remove any possibility that the leak could be in one of the pipe?
- what other area could be subject to leak in a fiberglass pool?
- how low can the water go before it become dangerous for the integrity of the pool? I heard fiberglass can not be emptied.
Thank you
Thank you
